LDD Mapcheck
For efficiency sake, the mapcheck report would need to look similar to the one generated by LDD. Many surveyors get used to looking at the same format of report over and over. If something is different it tends to throw them off when reviewing the project.
Custom Mapcheck
I would however, like to have another report with the ability to change the order it is presented. It is easier to follow along while checking a legal description if the information is in the same order it is written. I would like to have the ability to customize the following:
1. Change the order of the calls.
2. The ability to select which calls appear.
3. The ability to round or truncate the values used in the closure. LDD currently rounds the angles and distances but truncates the area. This makes creating multiple parcel mapchecks that add up to the overall boundary a pain.
4. The ability to turn on or off the coordinate values of each call.
5. The ability to see point numbers of the nearest point within a preset positional tolerance. A point filter would also be nice to weed out topo shots that may be within the tolerance. Maybe the ability to include which point groups are used when checking the tolerance of the parcel corner to the found point.
6. The ability to add a call out or designation as to whether the curve is tangent, non-tangent, reverse, compound, to the left or right. It should also label if the departing course is tangent or non-tangent to the preceding curve.
Give me some time and I will come up with more wishes.
Stacy Dunn
