Solved by Jeff_M. Go to Solution.
Jeff,
Thank you very much... I thought I was just a doorknob that could not follow directions (well sometimes I am). I appreciate you looking into this.
Thank,
Chris
Your Name
Your Name
Thank you Jeff...
This modified one works great. I just have one problem, I cannot get the report to show up in my toolbox permenately. I edit the tool box and I have done all of the following:
1. Added a new tool to the Parcel Reports. Executes fine in the edit toolbox, but after saving, it does not show up in the Toolbox Reports manager.
2. Added a new Category, then new tool. Report executes but still does not show up in the Toolbox Reports manager.
3. Added a new Root Categor, then Category, then Tool. Report executes but still does not show up in the Toolbox Reports manager.
In each of the previous cases everytime I close the toolbox Editor, the Report does not show up and if I open the editor again, the Tool/Category is gone.
Am I missing a step somplace that will allow me to add this as a permanent fixture to Civil 3D so I can use it easily on multiple projects?
Chris
I'll Check with IT in the morning, but it allowed me to create a new folder in that location
Thank You very much for sharing this Jeff!!!!
This is by far a huge improvement over the out of the box version. I knew there must be a better way to get a report. Glad I ran across this thread. And also a big thanks for the continuing effort on getting it to work with previous releases! We are currently using 2012 but will be switching all projects to 2014 in the near future.
Jeff,
I'm struggling with the same issue Shilo4082 had. I can't get the path in the report manager to stick. I'm not sure what the resource file is that needs to be in the same folder is. I copied both files to: C:\ProgramData\Autodesk\C3D 2012\enu\Data\Reports\Net
(using 2012)
Update: renaming "C3DReport_JMM.dll" to "C3DReport.dll" allows the report to execute. This produces some errors, but you still get the report. Be sure to backup the original "C3DReport.dll".
Jeff, if you revisit these again, can you included the site name and/or the Lot name instead of the #? I use separate sites for easements and give them unique names to help the map checker find their place.
Thank you, Jeff!
Update 2: (for 2012)
For the benefit of others (and myself the next time I get a new machine): the last batch of files require the macro name to be "ParcelMapCheck_Report" and not "ParcelMapCheck" as it was mentioned for an earlier version in this thread, and he last three files Jeff posted all need to be in the same folder.
One more image that I neglected to upload in my last post. Creating a new custom report seems to stick.
Jeff,
It seems as though I am doing something wrong. I am using civil 3d 2013 and cant for the life of me get the exported text file to change in format. I am going to sleep after drying out my eyes, on and off these 6 pages since about 7 this evening. Can’t really find a step by step set of instructions and from what I do understand (where to put the files) is that I’m far less skilled than I originally thought and i didn't sit very high before. I would greatly appreciate the step by step for civil 3d 2013 as I am clearly doing something wrong.
Thomas
Thomas, this should be all you need do:
Download the 2013 version zip from THIS message to a place you can find it.
In Windows Explorer, browse to where you saved the zip file. Right-click on it, select Properties, on the General tab if there is a button labeled Unblock, press it, then exit the properties. Now you can extract the dll in the zip and save it to a location you will remember...perhaps "Documents\Custom Reports\" or something like that.
Here is a screencast showing the remaining steps (to get the name of the command to execute I went to an already working entry, you obviously won't have that, use the name it shows in the video):
Hope that helps!
Jeff,
Murphy has found me today. I was leaving the office this afternoon and noticed I had a flat tire, of course literally no tire shop within 50 miles of me (over ten to choose from) carried my size. Needless to say, I haven't had the time to do much other than thank you for yet another prompt response. I greatly appreciate your willingness to coach me through this. You’re truly an amazing individual and I admire you not only for your knowledge but again, for your willingness to help such a c3d noob as myself. Have a great evening!
Thank you so much!
Thomas.
I cant seem to get it to execute. I get an error. See attached.
Ultimately, what I am looking to do though is just to have it export bearing and distances along with area. Any help would be greatly appreciated.
