Hello I would like to have my bearings come out without the Northing and Easting tags on the front and back of the bearing, I cant find the option to get rid of them.
eg.
What I have N90 15' 30"E and what I want is 90 15' 30" I have been looking thourgh text component editor but cant find how to swithc it off.
Also I would like to have my distance after the bearing and the whole bearing to spread accross the line evenly spaces with the distance on the end.
eg.
320 15' 30" 12.562
Any help would be appreciated.
Attached is a screen shot of my current settings
Solved by wfberry. Go to Solution.
I can only assume that you want to use Azimuth directions. You can start by going to Drawing settings and in the Ambient Settings tab select Direction and change the Measurement Type to either North or South Azimuth.
I have never used Azimuth direction and am thinking that there must be a Template (.dwt) for this use. If not, all the labels will have to be individually changed as well.
As far as "spreading" your labels deg, min., secs, distance out, you will have to do this individually for each label by putting spaces in the label. (As Far as I Know).
Bill
There is a setting for "Spaced" on the angular labels. I think it adds a space between the symbols. With the bearings labels, it also adds a space between the N and E at the beginnning and end of the labels. You need to set yoru anglular types to azimuth and then create a label with azimuth instead of bearing. That will give you the azimuths. I have never done it, but if I'm not mistaked, you can also choose between north azimuths and south azimuths.
Surveyor Lee
