A few questions:
1. Did you set the automatic line and curve tag counters to begin at 1? Or
did you change the manual counters? If you want tag numbers to
automatically begin at 1, you must set the start values of automatic
counters to 1.
2. Did you try using the tag renumbering tool? If you are getting
nonconsecutive numbers, it looks like you are using the renumbering tool
that has an increment value of greater than 1. Try renumbering them again
and set the start and increment values equal to 1.
3. Did you delete the old tags completely or just turned them into labels?
If you have just turned them into labels, then they still have tag numbers
and those numbers cannot be reused. In that case, you may want to delete
those labels to start numbering from 1.
Smita
wrote in message news:4987000@discussion.autodesk.com...
I previously labeled some parcel curves with tags & deleted them. Now when
I label I't's starting @ 22 & labeling nonconsectutively. I Why?
PS: I changed the Site Properties to begin @ 1
