Civil 3D Forum
PROFILE ELEVATION LABEL ISSUES
6 REPLIES 6
Ash254
705 Views, 6 Replies
Is there a way for the program to automatically change profile elevations of intersecting roads.
Say for example i have two intersecting roads ROAD A and ROAD B.
On my ROAD A profile at station 0+300 i have a proposed road elevation of 9.5
On my ROAD B profile at station 0+000 (intersecting point) I have the same proposed road elevation of 9.5
Now i change my ROAD A profile at station 0+300 to 10.3
Is there anyway to allow the program to automatically change my ROAD B profile elevations to 10.3
IF NOT--
and I have to use the Annotate > Add Labels > Profile View > .......................... labels,
Is there a way for those labels to link across the profiles such that
On my ROAD A profile at station 0+300 i put the label at the elevation of 9.5
On my ROAD B profile at station 0+000 (intersecting point) I have the same label at the elevation of 9.5
Now i change my ROAD A profile at station 0+300 to elevation of 10.3 then is there a way for it to automatically raise the ROAD B elevation label
So that I would know, without having to manually check through, that there is a discrepancy between those intersecting roads.
So the real jist of my query is whether I can link my alignments, profiles or annotation labels.
Thanking you in advance for your assistance.
6 REPLIES 6
Joe-Bouza
in reply to: Ash254
Sure. create an intersection with the intersection wizard; it locks the secondary profile to the primary. you can use this ant not create the intersection object if you don't want one
Joe Bouza
Ash254
in reply to: Joe-Bouza
Thank you i will try it out
owenmull
in reply to: Ash254
Joe's solution is the best, and that will work. It is a trick I've used several times before. Just create a dummy intersection with nothing in it, and it will accomplish what you seek,
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
Ash254
in reply to: owenmull
thanks guys for your help but do I have to create a corridor for the proposed road first??
troma
in reply to: Ash254
No corridor needed.
Mark Green
Working on Civil 3D in Canada
yosephk
in reply to: Ash254
That's great. Thank you for sharing.
Windows 10 Pro x 64
16 GB Ram
Intel Xeon E3-1220 V2 @ 3.1 GHz
NVIDIA Quadro 600
Civil 3D 2019
Rail Community
