We have a client who proposes to lay a road of some 1,900 ft. in length across some rough terrain. He provides us with a sketch, and we create an alignment across his topography.
The resultant profile comes in with a horizontal scale of 1:1 and a vertical scale of 1:10 (see appended image), creating an exaggerated vertical topography that horrifies the client, who insists that his proposed route "doesn't look like that."
In short, the client would like to see a 1:1 vertical scale along with his 1:1 horizontal scale. How do we do this? We don't seem to find a simple way to set these scales in the Profile style settings.
Also, can the EXISTING profile scales be altered within the drawing while the client watches, or must we create a new style each time we want to change the style display ratios?
Many thanks!
Solved by Jay_B. Go to Solution.
Set the Profile view scale's here: Settings Tab of Toolspace>Profile View>Profile View Styles>Style Name>Graph Tab>
Current Horizontal scale = whatever the dwg Model Space scale is set to.
Vertical Scale can be changed to desired exaggeration by changing the Vertical Scale value.
I am having the same issue with my drawing. However, when I change my scale through the advised location, the drawing itself does not change. When I go back to change the scale again, it saved the previous changes. I click apply and it still doesn't alter the drawing. HELP!
