In the Pressure Pipe Style used, display only the "Pipe Centerline" component and assign a lineweight to the style.
Or use the bylayer "lineweight" setting in layer manager if the pipes are on their own dedicated layer.
Settings Tab of Toolspace>Pressure Network>Pressure Pipe>Pressure Pipe Styles>Pipe Style used
This assumes you use "lineweights" when plotting.
