Civil 3D Forum
POINTS in drawing NOT accessible
10 REPLIES 10
Message 1 of 11
335 Views, 10 Replies
Existing points in drawings show up on the screen but I cant LIST, EDIT or EXPORT.
When I ADD points in the same drawing all functions work correctly but only for the new material .
Any suggestions?
10 REPLIES 10
Message 2 of 11
sboon
  • Are these point objects selectable?
  • Can you change their style or label styles?
  • Are they visible as part of any point group?
  • Have you audited the drawing?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 3 of 11
AllenJessup
Are the points possibly in a locked Survey database?
Allen Jessup
from my nook tablet
Allen Jessup
CAD Manager - Designer
Message 4 of 11
wfberry
The first question I have is if you cannot list them, how do you know they are points?
Bill
Message 5 of 11
Joe-Bouza
in reply to: AllenJessup
My computer says 5:27 am. You rock!
Joe Bouza
Message 6 of 11
Joe-Bouza
Defpoints layer 0 frozen?
Joe Bouza
Message 7 of 11
AllenJessup
in reply to: Joe-Bouza
Joe. Mine says 8:27. Might want to check your settings or battery.
Allen
from my nook tablet
Allen Jessup
Message 8 of 11
in reply to: wfberry
They appear on screen as POINTS.....Point number, description and label.
I can select them but NOTHING comes up.....no LIST, no STYLE....nothing.
I will do an audit and check if there is a database but cant do much today since I'm not at my work computer.
Any other suggestions?
Message 9 of 11
Joe-Bouza
My guess is they are not c3d points.
Joe Bouza
Message 10 of 11
Jay_B
Try selecting one of the items with the Properties Palette open.
If they are Civil 3D points it should say "Cogo Point" at top of palette, and if it says Cogo Point and Survey Point is "True" under data then it's also a "Survey Point".
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 11 of 11
IanMcClain
Try using the point conversion utilities under the pulldown Points>Utilities; if they are ACAD or LDD points you can update them to C3D points.
Ian McClain
Rail Community
