AutoCAD Civil 3D General
Active Contributor
mikerobe100
Message 1 of 6 (235 Views)
POINT LOCATIONS INCORRECT
235 Views, 5 Replies
11-18-2013 02:00 PM
I import a text file. I look at the coordinate list in the toolspace under the survey tab and the coordinates listed are correct. but the nodes in the drawing are 4 feet off. any idea as to why this is happening?
sboon
Message 2 of 6 (222 Views)
Re: POINT LOCATIONS INCORRECT
11-18-2013 03:03 PM in reply to: mikerobe100
Post a copy of the drawing to this forum.  Someone will be able to look at it and probably give you an answer.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Distinguished Mentor
Pointdump
Message 3 of 6 (197 Views)
11-18-2013 05:11 PM in reply to: mikerobe100
Mike,
If the coordinates listed are correct, what is 4 feet off? And yes, please post a drawing.
Dave
Dave
Mohave Valley, Arizona
HP DV7 Laptop
Intel Core i7-3820QM 3rd Generation Quad Core 2.7 GHZ CPU
16 GB DDR3 RAM ( 2 DIMM ) / 180 GB SSD
Nvidia GeForce 650M Graphics w/2 GB Memory
Windows 7 Professional 64 bit / AutoCAD Civil 3D 2014
Active Member
KirkN
Message 4 of 6 (188 Views)
11-18-2013 06:38 PM in reply to: mikerobe100
Check your Zone in the survey database as well as in the drawing. Sounds like transformation from US Feet vs. International Feet.
Distinguished Contributor
SurveyorLee
Message 5 of 6 (170 Views)
11-18-2013 08:07 PM in reply to: KirkN
this sounds like the difference in international feet vs. US feet, or at least in SC it's between 4 and 5 feet.
Surveyor Lee
Active Contributor
mikerobe100
Message 6 of 6 (147 Views)
11-19-2013 04:57 AM in reply to: KirkN
My zone setting was correct but my database setting was wrong. The funny thing is that I worked in a different project and didnt have this problem. Not sure how it happened.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
