I recently requested a .tin file from our surveyor. He sent the file. When making a surface from the .tin file, I got the error message, need the .pnt file as well. When I requested the .pnt file from our surveyor he sent a .txt file. It has the format x, y, z coordinates in a list. Without having to call and request info from the surveyor again, which he may not know how to do, can I convert the .txt file to a .pnt file?
Example of .txt file:
2,10025686.85,3098661.38,631.18,2 712
4,10025978.82,3098436.88,633.01,2 712
7,10024706.90,3098675.65,626.08,712 CA INC
8,10024261.13,3098602.11,634.21,712/TF CONTROL
9,10024780.84,3097515.40,630.93,12 60D
thanks,
mando
Solved by rkmcswain. Go to Solution.
The TIN extension is not exclusive to Autodesk. There is two (or more) possibilities.
Ask your source what created the TIN file. If it's the first case, they will need to provide a LandXML or other format.
The surveyor indicated the file came from Carlson Surveying with Autocad.
They said they can't generate a .pnt file. Only a .txt file and everyone they have sent it to has not had a problem with it. Is this new to ACAD 2012?
They also indicated I could use the .txt file to import points into my drawing. Is this true and how?
mando
We can read the Carlson Binary TIN in a development build of MapWorks. Carlson in AutoCAD should be able to export a LandXML file for you. If that's not an option, zip and post the TIN file and I should be able to convert it.
The Carlson TIN file has the point information in it. They don't need to generate a PNT file and it wouldn't do you any good anyway.
Civil3D has the built-in ability to import points, including text files. If the TXT format is P,N,E,Z,D then you can simply change the extension to AUF and go. I suppose you could import the points and (somewhat) recreate the TIN, although it could be a slightly different interpretation.
mando
In the future, just ask for a LandXML file of the surface, one file, one step, no problems.
If they can't or won't do that, then ask for a DWG file of the triangles (not Contours!)
rkmcswain wrote:ask for a DWG file of the triangles (not Contours!)
I do not concur with you, sir.
If we have contours, we easily create 3D surfaces, or we can plot a rich 2D plan map.
But if you have triangles, you must rebuild everything: in other words, contours are "the" start, whereas TIN are "the" end of the road.
@antoniovinci wrote:
I do not concur with you, sir.If we have contours, we easily create 3D surfaces, or we can plot a rich 2D plan map.But if you have triangles, you must rebuild everything: in other words, contours are "the" start, whereas TIN are "the" end of the road.
You have it backwards. Contours are a REPRESENTATION of a surface. The triangles ARE the surface.
http://en.wikipedia.org/wiki/Delaunay_triangulation
Thanks for all the good answers. I was looking for spot shots to do some fine grading. When I imported the .txt file and set it to P,N,E,Z,D it worked great. in future, rkmcswain, i will ask for the LandXML file. I learned how to import the points from .txt file so if anything I learned something. That is good right?
I think I see what you mean by contours are the start and tin is the end of the road. Do you mean you can manipulate tin lines to fine tune your contours, right? If I receive contours, I would have to create a surface from poly lines and change properties to tin surface, right? This will not give me the points I was looking for from the get go. I retract my statement, I guess I don't understand the road statement.
Thanks and have a good weekend,
mando
I guess you're joking, man...
Contours are like the foundation of your house, and triangles are the roof: what's more useful?
@rkmcswain wrote:
Contours are a REPRESENTATION of a surface. The triangles ARE the surface.I guess you're joking, man...
When a surveyor goes into the field to collect information for the topography map, does he shoot contours, or does he shoot points with elevation?
Pretty much every topo I have seen starts with points, from which TIN lines can be drawn, from which contours can be interpolated. I don't believe I've ever seen it done the other way around.
Jeff_M wrote:does he shoot contours, or does he shoot points with elevation?
He shoots points with elevation, then he comes back home, and the very first thing he makes is.. contours from those points.
Contours are the base for every serious topographic plan: how did you project before computer era?
Answer: in 2D, on a contour basis, trust me.
If somebody lets me choose between a bunch of 3Dfaces (TIN) or a shape with elevated contours, I go with the second one, without no doubt, dear Jeff.
@Jeff_M wrote:does he shoot contours, or does he shoot points with elevation?He shoots points with elevation, then he comes back home, and the very first thing he makes is.. contours from those points.Contours are the base for every serious topographic plan: how did you project before computer era?Answer: in 2D, on a contour basis, trust me.If somebody lets me choose between a bunch of 3Dfaces (TIN) or a shape with elevated contours, I go with the second one, without no doubt, dear Jeff.
The first thing that gets done with points are that they are added to a surface in civil 3d from which trianlges are created, from which contours are interpreted. Check out what gets changed when contours are smoothed.
When I carry out a topo survey I measure points (and breaklines) that will create a surface model that will give the best representation in the computer of the actual ground, based on triangles.
Before computers, surfaces were drawn with contours, which were calculated from the points that surveyors measured. The surveyed points were plotted onto paper then measured between to calulate the elevations that were to be drawn as contours. The contour lines would then be drawn smoothly between all the calculated elevations of the same height to give your contour plan. The same process that occurs with a tin surface in computers.
Contours are a lie. I would MUCH rather have the triangles of the surface then an approximation of the surface aka contours. If you build a surface from contours, what is happening between the contours? You have absolutely no idea. If you get the triangles, you have the maximum amount of information from that surface. Do you build from contours? No. You build from points. The contours are simply a graphical representation of those points that make it simple for us as humans to see what is going on.
I hate to say it but I disagree with you, Antonio (I'm assuming that's your first name). But hey, that's the great part about this discussion group, people disagreeing with you is a great way to learn.
Brian:
The biggest problem that I have here is agreeing with Jeff, ALL THE TIME.
Oh well, maybe, someday!
Bill
I am going to consider this issue resolved for me. In future I will ask for LandXLM file. I was actually looking for points. When I received the .txt file with point information, I imported .txt file and got what I was looking for. I appreciate all the good answers. When I called the surveyor, he didn't know anything about a .pnt file. I use him regularly therefore I will just get the .txt file and insert it.
Thanks again,
Mando
tell your surveyor to throw away that toy for software he has and get some real software. i always have problem with surveyor that have carlson. i bata tested it when it first came out and even meet with the developer to get him to fix the problems. seems like they still have some of the same problems today.
contours CAN be basis for work if the contours are from an Aerial Survey using photogrammitry and mathematical cmoputations to out put contours...
Different types of survey are source data are applicable to different project types and accuracies with most detailed contouring requiring field survey which uses the compilation of points to create a grid surface or triangulated irregular network (surface). Surfaces can also be made from aerial survey points acquired from LiDAR for instance.
http://en.wikipedia.org/wiki/Triangulated_irregular_network
Carlson is actually a very good program for Survey, it works very well with data collectors (Trimble I think?). Civil 3D is a good upgrade but not being a surveyor, I can't say if Civil 3D handles field to finish as well as Carlson or how well it works with Data Collectors. Carlson actually works quite well with Civil 3D and to the O.P.... consider asking for:
XML of surface
text file of points
2D Cad linework
YOU DON'T need their triangles, their cad blocks (survey shots) but you PROBABLY want their contours to get their representation of the contours to make sure Civil 3D's interpretation of the XML file matches....
I'm glad you see it for what it is,,,, survey the points on the ground, create tin from those points and the generate contours from the tin. Never use contours to work from,,,weeding kills the accuracy.
