AutoCAD Civil 3D General
aportillojr
Message 1 of 18 (2,580 Views)
PNT files
2580 Views, 17 Replies
03-13-2012 01:10 PM
I recently requested a .tin file from our surveyor.  He sent the file.  When making a surface from the .tin file, I got the error message, need the .pnt file as well.  When I requested the .pnt file from our surveyor he sent a .txt file.  It has the format x, y, z coordinates in a list.  Without having to call and request info from the surveyor again, which he may not know how to do, can I convert the .txt file to a .pnt file?
Example of .txt file:
2,10025686.85,3098661.38,631.18,2 712
4,10025978.82,3098436.88,633.01,2 712
7,10024706.90,3098675.65,626.08,712 CA INC
8,10024261.13,3098602.11,634.21,712/TF CONTROL
9,10024780.84,3097515.40,630.93,12 60D
thanks,
mando
Valued Mentor
TerryDotson
Message 2 of 18 (2,579 Views)
Re: PNT files
03-13-2012 01:23 PM in reply to: aportillojr
The TIN extension is not exclusive to Autodesk.  There is two (or more) possibilities.
  1. The TIN file was created with GeoPak, which is a proprietary format you can't use.
  2. The TIN file is a LandDesktop TIN, which should have a binary PNT file in the same folder, likely the same date/time.  If you drop this in notepad it will look like garbage.
Ask your source what created the TIN file.  If it's the first case, they will need to provide a LandXML or other format.
aportillojr
Message 3 of 18 (2,543 Views)
Re: PNT files
03-14-2012 08:31 AM in reply to: TerryDotson
The surveyor indicated the file came from Carlson Surveying with Autocad.
They said they can't generate a .pnt file.  Only a .txt file and everyone they have sent it to has not had a problem with it.  Is this new to ACAD 2012?
They also indicated I could use the .txt file to import points into my drawing.  Is this true and how?
mando
Valued Mentor
TerryDotson
Message 4 of 18 (2,536 Views)
Re: PNT files
03-14-2012 10:47 AM in reply to: aportillojr
We can read the Carlson Binary TIN in a development build of MapWorks.  Carlson in AutoCAD should be able to export a LandXML file for you.  If that's not an option, zip and post the TIN file and I should be able to convert it.
The Carlson TIN file has the point information in it.  They don't need to generate a PNT file and it wouldn't do you any good anyway.
Civil3D has the built-in ability to import points, including text files.  If the TXT format is P,N,E,Z,D then you can simply change the extension to AUF and go.  I suppose you could import the points and (somewhat) recreate the TIN, although it could be a slightly different interpretation.
rkmcswain
Message 5 of 18 (2,513 Views)
Re: PNT files
03-16-2012 08:29 AM in reply to: aportillojr
mando
In the future, just ask for a LandXML file of the surface, one file, one step, no problems.
If they can't or won't do that, then ask for a DWG file of the triangles (not Contours!)
antoniovinci
Message 6 of 18 (2,511 Views)
Re: PNT files
03-16-2012 08:51 AM in reply to: rkmcswain
I do not concur with you, sir.
If we have contours, we easily create 3D surfaces, or we can plot a rich 2D plan map.
But if you have triangles, you must rebuild everything: in other words, contours are "the" start, whereas TIN are "the" end of the road.
rkmcswain
Message 7 of 18 (2,507 Views)
Re: PNT files
03-16-2012 09:13 AM in reply to: antoniovinci
You have it backwards. Contours are a REPRESENTATION of a surface. The triangles ARE the surface.
http://en.wikipedia.org/wiki/Delaunay_triangulation
aportillojr
Message 8 of 18 (2,506 Views)
Re: PNT files
03-16-2012 09:14 AM in reply to: aportillojr
Thanks for all the good answers.  I was looking for spot shots to do some fine grading.  When I imported the .txt file and set it to P,N,E,Z,D it worked great.  in future, rkmcswain, i will ask for the  LandXML file.  I learned how to import the points from .txt file so if anything I learned something.  That is good right?
I think I see what you mean by contours are the start and tin is the end of the road.  Do you mean you can manipulate tin lines to fine tune your contours, right?  If I receive contours, I would have to create a surface from poly lines and change properties to tin surface, right?  This will not give me the points I was looking for from the get go.  I retract my statement, I guess I don't understand the road statement.
Thanks and have a good weekend,
mando
antoniovinci
Message 9 of 18 (2,502 Views)
Re: PNT files
03-16-2012 09:33 AM in reply to: rkmcswain
I guess you're joking, man...
Contours are like the foundation of your house, and triangles are the roof: what's more useful?
Jeff_M
Message 10 of 18 (2,497 Views)
Re: PNT files
03-16-2012 09:59 AM in reply to: antoniovinci
When a surveyor goes into the field to collect information for the topography map, does he shoot contours, or does he shoot points with elevation?
Pretty much every topo I have seen starts with points, from which TIN lines can be drawn, from which contours can be interpolated. I don't believe I've ever seen it done the other way around.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
