AutoCAD Civil 3D General Discussion
Valued Mentor
owenmull
Message 11 of 29 (339 Views)
Re: PNEZD file import issue.
04-20-2012 12:29 PM in reply to: afdelarosa
Ok. I see what is going on here.
I know this probably isn't the exact solution you are looking for, but try opening the point file itself in Excel (or an open source spreadsheet program, like OpenOffice) and save it as a .csv
You might have to do some cleanup, but try that, and then import that .csv as a PNEZD (comma delimited).
-Owen
Windows 7 x 64 bit
NVidia Quadro K3000M Dual Monitor
32.0 GB RAM
Intel Core i7-3820QM @ 2.70 GHz
Civil 3D 2013 SP 2
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
*Expert Elite*
AllenJessup
Message 12 of 29 (338 Views)
04-20-2012 12:30 PM in reply to: afdelarosa
This is how it should look:
I notice you have filtering on. I don't know if that's blocking the PNEZD format. Try turning it off.
Allen
Valued Mentor
owenmull
Message 13 of 29 (336 Views)
04-20-2012 12:31 PM in reply to: AllenJessup
Yes, yes, to Obi-Jessup you listen!
lol
-Owen
Windows 7 x 64 bit
32.0 GB RAM
Civil 3D 2013 SP 2
*Expert Elite*
AllenJessup
Message 14 of 29 (330 Views)
04-20-2012 12:41 PM in reply to: owenmull
I'm not sure yet. I've tried turning on filtering while importing a TXT file and it doesn't filter out PNEZD (comma delimited). It's possible that the files are missing of the path is set wrong on the OPs computer. We'll have to wait for a reply.
Allen
Distinguished Contributor
afdelarosa
Message 15 of 29 (324 Views)
04-20-2012 12:59 PM in reply to: AllenJessup
*Expert Elite*
AllenJessup
Message 16 of 29 (321 Views)
04-20-2012 01:02 PM in reply to: afdelarosa
That looks like it. Do the points come into the drawing OK?
Allen
Valued Mentor
IanMcClain
Message 17 of 29 (320 Views)
04-20-2012 01:04 PM in reply to: afdelarosa
Try renaming the .txt to .csv
If that doesn't work, open it in text pad do a find and replace of ",<null>," to be just ",".
PNEZD should recognize .txt. You could change the default extension for PNEZD to .txt. That is what mine is.
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
afdelarosa
Message 18 of 29 (318 Views)
04-20-2012 01:13 PM in reply to: IanMcClain
Ok, we are getting somewhere here. I turned the filtering off. I replaced the <null> for "0". Imported my points but the descriptions are not coming in. (I tried the .cvs part but I normally just grab the point file, not really export them when it comes from the field).
Thanks again!
Valued Mentor
owenmull
Message 19 of 29 (310 Views)
04-20-2012 01:20 PM in reply to: afdelarosa
Ahhh, good old forums. We might not *always* solve the problem, but we will sure have fun confusing you! LOL!!!
-Owen
Windows 7 x 64 bit
32.0 GB RAM
Civil 3D 2013 SP 2
*Expert Elite*
Jeff_M
Message 20 of 29 (299 Views)
04-20-2012 01:56 PM in reply to: afdelarosa
You could just create a copy of the PNEZD(comma delimited) point file format and edit it so the elevation column is unused.
Jeff_M, also a frequent Swamper
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
