I'm using the PIPE2EXCEL.dvb (macro file) for my pipe network analysis. (Which I get from http://au.autodesk.com/?nd=class&session_id=3177)
Follow the steps as per the videos,
I tried to execute the Export to Excel (Attachment 01), but getting error message (Failed to execute Export to Excel - Attachment 02)
I'm not familier with Storm & Sanitary analysis 2012. Using AutoCAD Civil 3D 2012, 64bit
Kindly have a look on my query
Najeeb
That VBA was not written for C3D 2012. It will not work unless it is modified. BTW, Rad does not work for Autodesk any longer, so that's why his email bounced back.
Thanks Matt,
Could you please more specific about the editing of VBA files? (Like which area need to be modified)
regards
Najeeb
I changed the version number & reference files in 2009 matched with C3D 2012 (attachment 01).
The macro file (PIPE2EXCEL.dvb) is working smooth in C3D 2012.
But....
When execute the IMPORT from EXCEL, Pipe size & slops are update automatically in plan and profile. Except the pipe size in labels, It is not update automatically, need to SWAP part (attachment 02)
Kindly have a look on my doubt
Thank you,
najeeb
