My coworker is getting the error shown in this screenshot. He is drawing pipes with structures when it appears. I opened the drawing file on my computer and it works fine. He is using Windows 7 64bit and I am using Windows Vista 32bit. We are both using Civil 3D 2012. Any ideas on what is causing this?
Solved by JessieQuilatan. Go to Solution.
I found the problem!
I had to convert the pipe and structure rules from VBA to .NET
Menu--> Pipes--> Utilities--> Convert VBA pipe and structure rules to .NET
I have created some custom structures & pipes (Rules & parts) using civil 3D 2012 (64 bit),
I wanted use this in to Civl 3D 2012 (32 bit). So do I need to convert this in to any format?
Note: Company PC has Civil 3D 2012 32bit.
Please advice
Thank you
najeeb
Hi Najeeb-
The .net converted rules work fine and appear to be compatible with both our 64 bit and 32 bit versions.
