Civil 3D Forum
Overriding Superelevation using an Outside Lane Elevation Method
2 REPLIES 2
ashleystrand
517 Views, 2 Replies
In my corridor I have used superelevation.  In a horizontal curve which has a cross slope of 4.5%, I have an intersection.  To allow for a smoother ride through a few lanes in the intersection I want to change the cross slope from 4.5% to 1%.  I was planning on doing this by using a Outside Lane Elevation Method of a Profile.  However, it appears that my super has precedence over my profile.  Is there are way to make this work?
2 REPLIES 2
BrianHailey
in reply to: ashleystrand
Not positive if this is necessary as I haven't messed around with super much in C3D but, if you don't find another way of doing it you could always create a new region with an assembly that isn't using the super and target the elevations.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
I would change the lane slope by changing the super elevation within the intersection by adding a user defined super elevation region to the alignment. This will allow you to make the transition from your current super to the desired super.
Cheers,
Peter Funk
Peter Funk
Rail Community
