AutoCAD Civil 3D General
neilyj
Message 1 of 7 (304 Views)
OverlayWidenMatchSlope2 Assembly Query
304 Views, 6 Replies
01-14-2013 03:42 AM
I have a corridor produced with the above assembly and have created a formation surface which looks good in 3D and is essentiallly the redline (Earthworks Outline) in the screenshot.
The widening to the left and right create vertical edges (I can't see a way to overcome this in the subassembly) so how can a surface be created as vertical sides are not permitted?? If I zoom in the triangles do have a gap but it seems to be less than 1mm as ID'ing points shows identical coordinates
REGENALL Regenerating model.
Command: id
Specify point:  X = 389260.169     Y = 424823.507     Z = 0.000
Command:
ID
I need the surface triangles to be exported for use in a 3rd party application but they do not form correctly and the earthworks outline in the area of the road is very wrong.
Any ideas/workarounds??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Product Support
AlmasSuljevic
Message 2 of 7 (262 Views)
Re: OverlayWidenMatchSlope2 Assembly Query
01-15-2013 09:01 AM in reply to: neilyj
Hi neilyj,
I think you will need to create a custom assembly to be able to avoid those vertical links.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
BrianHailey
Message 3 of 7 (259 Views)
01-15-2013 09:23 AM in reply to: neilyj
If the surface is correct in Civil 3D but not in the other application, it sounds like the other application is the one with the issue.
I've seen other programs, such as Revit, that can't duplicate a surface that was created in Civil 3D. Is it the fault of Civil 3D? No, that other surface just doesn't do topos well. Is this the case iin your situation? I really don't know.
As for the vertical data issue, if your corridor has vertical information in it (or overlapping) make sure you set an Overhaing Correction to the surface (doesn't really matter which one in most cases). This will do exactly what you are seeing, put in a slight offset to the vertical location.
Hope this helps.
neilyj
Message 4 of 7 (252 Views)
01-15-2013 01:07 PM in reply to: neilyj
the problem seems to be that the offset correction is less than 1mm which the other software has trouble with...
neilyj
Valued Mentor
fcernst
Message 5 of 7 (246 Views)
01-15-2013 01:45 PM in reply to: neilyj
Take your coordinate decimal precision out farther, and let's see what the "vertical" offset it really is....
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
sboon
Message 6 of 7 (239 Views)
01-15-2013 02:06 PM in reply to: neilyj
If the other software requires a 1mm minimum then it may be possible to use generic links and some trickery to create a datum surface that suits the requirement.
Can you post the drawing, or at least a sample piece with the assembly included?
neilyj
Message 7 of 7 (227 Views)
01-16-2013 12:39 AM in reply to: sboon
Thanks for the replies - I'm on another project at the moment but I'll come back to this one later in the week
neilyj
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
