Civil 3D Forum
Overlapping Geometry Point and Major Station Alignment Labels
5 REPLIES 5
tom
1817 Views, 5 Replies
Using Civil 3d 2012, if we are labeling both the major stations as well as geometry points of our centerline alignment, is there a way to control what happens when a geometry point falls on a major station?  For example, if there is a tangent-tangent intersection that happens to occur at station 5+00, is there a way to only see the Geometry Point Label and not the one single Major Station Label at 5+00?  Thank you.
5 REPLIES 5
Joe-Bouza
in reply to: tom
you can ctrl pick station 5+00 and delete it. Maybe someone could wright a fancy expression.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
wfberry
in reply to: Joe-Bouza
Joe:
I don't think you can wright a wong!
Bill
tom
in reply to: tom
Joe,
Thanks so much.  I didn't know I could do that.
As an extension of my original question, is there a way to modify or format the text in a single alignment label.  For example, If I used the control delete and erased the Major Station Label at 5+00, but the text for the Geometry Point Label at PI 5+00 happened to be on top of a manhole.  If there was no good place to drag the label that was out of the way of any other important feature or line work, is there a way to say insert a line break in the text, or maybe change the size of the text for that one single label?  If not, I guess I could use the control + delete and just manually create a label for that one point.
Thanks again.
Jeff_M
in reply to: tom
CTRL+Select, right-click or select from ribbon, Edit Label Text
Jeff_M, also a frequent Swamper
tom
in reply to: tom
Duh... I keep forgetting to look at the ribbon.  Thanks so much, you all have been great.
Rail Community
