AutoCAD Civil 3D General
sboon
Message 11 of 17 (159 Views)
Re: Overall Parcel
09-19-2012 08:38 AM in reply to: castled071049
Are you sure abou that?  I'm looking at the Parcel-2C drawing from the Tutorials.  Toolspace says that there's only 11 parcels in the drawing and that matches what I see.  How do I get an label onto the overall parcel?
jmayo
Message 12 of 17 (158 Views)
Re: Overall Parcel
09-19-2012 08:40 AM in reply to: jmayo
If the you want the total area labeled you also may just want an area label on the Site. Note this would assume the entire site only the one large existing parcel.
Do this in Prospector by expanding the Site tree and right click on Parcels. You can add an area label to the site in this dialog.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Active Contributor
Message 13 of 17 (155 Views)
Re: Overall Parcel
09-19-2012 09:22 AM in reply to: jmayo
Thanks I saw this and it works. Now I am trying to give the site parcel a different style that the individual style. Its not working like I thought it did before. The outer overall parcel should be able to have a style that is a different color but it doesn't seem to work. -John
Civil 3D 2014
Win 7
Distinguished Mentor
Message 14 of 17 (155 Views)
Re: Overall Parcel
09-19-2012 09:23 AM in reply to: sboon
As johnm pointed out, right click on Parcels in the Prospector (under the appropriate Site), go to "Propoerties", and attach a Site area label style. (See attached file.) In the red oval, upper right corner, the label for the automatically created overall site appears. It is typically named Lot 0, and does not appear in the listing of Parcels.
Create a label to suit for the overall site, attach it via the Site Parcel Properties as described above, then crack a cold, frosty one, kick back, and proclaim to all what a freakin' genius you are.
Message 15 of 17 (154 Views)
Re: Overall Parcel
09-19-2012 09:25 AM in reply to: erwebsite
In the same place as you attached a label, you can create and attach parcel styles as well.
sboon
Message 16 of 17 (152 Views)
Re: Overall Parcel
09-19-2012 09:36 AM in reply to: castled071049
Kudos for everybody !!
jmayo
Message 17 of 17 (146 Views)
Re: Overall Parcel
09-19-2012 10:50 AM in reply to: erwebsite
Go back to the Site's parcel properties dialog. Assign the parcel style you want, hit the Apply button and then look at the list of Parcel Style Display Order and make sure the style assigned above is at the top of the list.
John Mayo, PE
IDSP 2014
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
