All of my custom optional pipe parameters display "undefined" in the parts list.
If I try to edit them to a string or value it will not save, reverts back to "undefined"
Any ideas on how to rectify this?
See Attached..
As far as I know, you cannot enter random strings to custom properties.
They need to be defined in the part, or in the AeccSharedPropertyLists.xml
Well,
I created them in 2010 and they worked fine unitl 2015.
The AeccSharedPropertyLists.xml file is for "lists", hence the name..
Went in and looked at this and you can just type in whatever you want in there. Yikes!
We have never used it that way, never had the need for user input, always made a list of standards.
The AeccParamCfg.xml file may be the issue.
<AeccDfParameter name="DEG" desc="Degree" context="Degree" index="0" datatype="String" usage="String_General" managelist="False" unit="" visible="True" internal="True"/>
That is the property I gave it a go on and it worked. other than that I might not be much help.
No updates.
SP1 had no fix for this..
