Issue is regarding running executable files. whenever i tried to executable file its open option dialog box or help dialogue box. i had make trusted klocation setting and executable file setting then also i am getting problem.
Solved by wfberry. Go to Solution.
Is there an error message or screen shot you can show us?
I'm sorry but I'm having trouble understanding what you're asking. I certainly mean no offense.
Don Ireland
Engineering Design Technician
You say you have added the path to the trusted location settings but still getting a problem. What is the problem? If it does not run do you see any messages?
What type of program are you trying to run? An executable (.exe), an addin (.dll), Lips (.lsp)?
it is an .lsp file. It is running perfectly. There is no issue with .lsp file.But while running code it opens Autocad option dialogue box i or help dialogue box n middle.
