When I open my template I get 2 drawings, can this be fixed?
How are you opening your template? Double clicking on the template file through windows explorer? By default, Civil 3D starts with Drawing1 open (that 1 drawing), then when you start another with a template, that the second drawing.
The answer to your question is you change your startup parameter to use a different UI.
Checkout the STARTUP variable.
You might also take a look at the help file for STARTUP SWITCHES, or customizing startup. I don't know which version you're using, so I can't paste a default path here.
The target in my shortcut doesn't reference a drawing that automatically starts, I have my STARTUP variable set to 0, so drawing 1 is automatically created based on my QNEW variable for the default template.
