Civil 3D Forum
Opening file within Autocad Civil 3D not Autocad (2014)
1 REPLY 1
1125 Views, 1 Reply
When i installed Autocad Civil 3D, its installs:
1) Civil 3d 2014 metric
2) Autodesk AutoCad civil 3d as Autocad 2014.
etc...
When i try to open .dwg file (on windows 8.1), i want it to open using Civil 3d 2014 metric.
By right-clicking and setting the open with default file, the only option i get is "Autocad application" but I cant select open with Civil 3d 2013 metric.
Currently i open Autocad civil 3d metric, then i open the file i want to use. Is there a certain way of opening .dwg?
Regards
Mayank
1 REPLY 1
neilyj666
You should have a desktop shortcut for civil 3d.
The application launcher should remember the last autodesk application you used so after you have opened a file you should be able to double click on a dwg and it'll open in civil
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
