When i installed Autocad Civil 3D, its installs:
1) Civil 3d 2014 metric
2) Autodesk AutoCad civil 3d as Autocad 2014.
etc...
When i try to open .dwg file (on windows 8.1), i want it to open using Civil 3d 2014 metric.
By right-clicking and setting the open with default file, the only option i get is "Autocad application" but I cant select open with Civil 3d 2013 metric.
Currently i open Autocad civil 3d metric, then i open the file i want to use. Is there a certain way of opening .dwg?
Regards
Mayank
neilyj (No connection with Autodesk other than using the products in the real world)
