Have you tried changing the color scheme? Might not help, but it is worth a try.
Yes, that was the first thing I did. All the colors there are fine except one. I can't read the Tab names. Just a small problem.
Is there a way to chamge the font from black to white?
Or change the background color?
I can remember the first time I looked at the circles with numbers mande from different color dots. They said tell me the number you see. I replyed what number.
J,
Can you post a Screen Shot of what you'd like to change?
Dave
Dave Stoll
Las Vegas, Nevada
I don't think there is an easy way to change any color of the ribbon interface. I know some modifications can be done, see this link. Although this blog was an April Fools joke, in the comments it shows that the UI can be modified in some ways. I would suggest contacting your reseller to see if they can create some custom code specific to your needs.
Switch Browsers... Or see this post http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Crashin-n-Hangin/m-p/5185033#M254613
i am also color blind and i also i have a huge problem with the color of the title of tabs of the ribbon also they are real hard to read
