AutoCAD Civil 3D General
Valued Mentor
Message 1 of 15 (2,482 Views)
Offset Problem 2013
2482 Views, 14 Replies
07-25-2012 08:05 AM
Has anyone else noticed a problem with offsetting polylines in 2013?  I constantly have polylines that when I try to offset them I get the "Cannot offset that object", yet it shows a preview of the object as if it was offset.
This isn't consistant and I haven't found anything to duplicate it every time.  But it happens on polylines that have arcs in them most of the time.  This is very frustrating when trying to offset the edge of pavement in order to get face of curb and back of curb.
I have attached a sample of one that is causing me issues.  Just to make sure it wasn't my template, I took the 2012 out-of-the-box acad.dwt and pasted the polyline in question into it, then saved as a 2013 dwg.  Try to offset it 0.5 to the inside and it won't work. If you try the outside, you'll get the preview of it, but it still won't offset.  This is a simple polyline with two lines and two arcs.  I've never had this kind of problem from any version of Autocad since R12 like I have with 2013.
I can explode the polyline and offset each individual part, but when you're dealing with around 50 polylines and probably close to 500+ lines & arcs, this becomes a huge problem.
Infrastructure Design Suite Premium 2014
Civil 3D 2014 x64
Windows 7 64-bit
6GB RAM
*Expert Elite*
jmayo
Message 2 of 15 (2,478 Views)
Re: Offset Problem 2013
07-25-2012 08:15 AM in reply to: engrtech
Remove the vertex at the mid point of the line and the pline will offset.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
*Expert Elite*
Jeff_M
Message 3 of 15 (2,475 Views)
07-25-2012 08:20 AM in reply to: engrtech
As John mentioned, remove the in-line vertex. For some reason, Autodesk changed how AutoCAD offsets polylines. I saved the drawing as a R2010 format and was able to offset it fine in 2010, but in 2012 & 2013 that vertex must be removed in order to offset.
*Expert Elite*
jmayo
Message 4 of 15 (2,473 Views)
07-25-2012 08:33 AM in reply to: Jeff_M
Odd huh? Even though the vertex is redundant it shouldn't effect the offset geometry. I mean even if you removed the end tangent the resulting curve still fits/computes. Better yet, remove the last vertex and leave the shorter tangent. Try the offset command and the error icon appears but the offset is created.
John Mayo, PE
IDSP 2014
*Expert Elite*
jmayo
Message 5 of 15 (2,465 Views)
07-25-2012 09:44 AM in reply to: jmayo
One more thing to note is that offsetting issues due to large coordinates did not seem to ba an issue with this.
John Mayo, PE
IDSP 2014
Valued Mentor
Message 6 of 15 (2,451 Views)
07-25-2012 11:16 AM in reply to: engrtech
Thanks for looking it it for me.  That would be a solution to this one polyline, but what about all my other ones?  I don't have time to track down which vertex of every polyline is causing the offset command to fail.  I've just been exploding the polyline and just offsetting every single piece of it in order to get it to work.
Basically, 2013 is costing us more money doing mundane edits that previous versions didn't require simply because Autodesk changed something that worked before with no issues.
Civil 3D 2014 x64
Windows 7 64-bit
6GB RAM
*Expert Elite*
AllenJessup
Message 7 of 15 (2,447 Views)
07-25-2012 11:20 AM in reply to: engrtech
Have you opened an SR with Autodesk?
Allen
*Expert Elite*
Message 8 of 15 (2,443 Views)
07-25-2012 11:28 AM in reply to: engrtech
Maybe try the C3D stepped offset command instead of AutoCAD's offset.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Valued Mentor
Message 9 of 15 (2,442 Views)
07-25-2012 11:31 AM in reply to: AllenJessup
Allen
Not sure what good it will do.  I can't reproduce it intentionally.  I guess I could try and see what happens.
I attached another DWG that has the previous edge of pavement as well as a curb island that's farther north for this same project.  Look at what happens when you offset the closed polyline that's up north by 0.5' for the back of curb.  It makes two polylines in the upper right corner that don't even match the original!
This is what is causing me so much headache.
Civil 3D 2014 x64
Windows 7 64-bit
6GB RAM
Valued Mentor
Message 10 of 15 (2,436 Views)
07-25-2012 11:34 AM in reply to: mathewk
It still does the thing. I thought of that, too, when I started having this issue.
Civil 3D 2014 x64
Windows 7 64-bit
6GB RAM
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
