I'm using Civil 3D 2010. Whenever I batch plot the cross sections, my offset assembly doesn't get plotted on the print. what I've been doing to get around it is to export to Autocad and then batch plot it from the autocad version. I can go through each sheet and plot the cross sections and it'll be fine, but I have a lot of cross section sheets so that option is not very efficient. Sometimes it's a hassle to export to Autocad coz it takes so long. I'm wondering if there's a setting that I need to adjust so that the offset assembly will show up on my batch plot.
