How come I cannot attach generic links to offset assemblies? Every other subassembly works except for generic links. Im pretty sure Im missing something here. Help would be much appreciated.
Solved by francisco_bobadilla. Go to Solution.
I'm not entirely sure what you mean by not being able to attach a generic link to an offset assembly - I just tried it and had no issues attaching a generic link. You can see the video of me attempting this here. Can you take a look at this and let me know what I might be doing differently from your workflow?
Hi Jason, after banging my head against my desk I finally figured out the issue. My offset alignment is not parallel to my main alignment. So in reality it was doing the links, I just wasn't seeing in the cross sections. When I went to the corridor editor sections I was able to see it if I switched to the assembly offset baseline. This explains why when I was'n t assigning an alignment to the offset worked.
Any reason why this is this way? (add to wishlist please). I just don't understand why a regular lane assembly would display in a section view and a generic link won't.
