AutoCAD Civil 3D General Discussion
ericdaniel
Message 1 of 3 (195 Views)
Offset Alignment with Superelevation Problem
195 Views, 2 Replies
08-06-2013 05:07 PM
Is there a way to set the superelevation data to offsets alignments in Civil 3d 2014.
Thanks in advance,
Eric
*Expert Elite*
sboon
Message 2 of 3 (179 Views)
Re: Offset Alignment with Superelevation Problem
08-06-2013 07:56 PM in reply to: ericdaniel
I just created two offset alignments in a test drawing and ran the superelevation wizard on both of them, just as I would for a centerline alignment.  Were you trying to do something else?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Active Member
eric-acevedo
Message 3 of 3 (172 Views)
08-06-2013 09:36 PM in reply to: sboon
Hi Steve,
The original error from superelev wizard was that the offset alignment did not have a design speed.
This speed was lost when I changed the start station to a range different from the centerline.
Now I made a test alignment too and created the offset alignment and I can run the superelevation wizard with no problem but The design speed of this new offset alignment is different from the centerline (100Km/h vs 60Km/hr).
After more testing I found a way to change the speed and the design criteria and is by setting the "update mode" in Offset Parameters tab from dynamic to static.
Eric
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
