Is there a way to set the superelevation data to offsets alignments in Civil 3d 2014.
Thanks in advance,
Eric
I just created two offset alignments in a test drawing and ran the superelevation wizard on both of them, just as I would for a centerline alignment. Were you trying to do something else?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Hi Steve,
The original error from superelev wizard was that the offset alignment did not have a design speed.
This speed was lost when I changed the start station to a range different from the centerline.
Now I made a test alignment too and created the offset alignment and I can run the superelevation wizard with no problem but The design speed of this new offset alignment is different from the centerline (100Km/h vs 60Km/hr).
After more testing I found a way to change the speed and the design criteria and is by setting the "update mode" in Offset Parameters tab from dynamic to static.
Eric
