Civil 3D Forum
Offset Alignment with Superelevation Problem
2 REPLIES 2
ericdaniel
907 Views, 2 Replies
Is there a way to set the superelevation data to offsets alignments in Civil 3d 2014.
Thanks in advance,
Eric
2 REPLIES 2
sboon
in reply to: ericdaniel
I just created two offset alignments in a test drawing and ran the superelevation wizard on both of them, just as I would for a centerline alignment.  Were you trying to do something else?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
eric-acevedo
in reply to: sboon
Hi Steve,
The original error from superelev wizard was that the offset alignment did not have a design speed.
This speed was lost when I changed the start station to a range different from the centerline.
Now I made a test alignment too and created the offset alignment and I can run the superelevation wizard with no problem but The design speed of this new offset alignment is different from the centerline (100Km/h vs 60Km/hr).
After more testing I found a way to change the speed and the design criteria and is by setting the "update mode" in Offset Parameters tab from dynamic to static.
Eric
Rail Community
