In C3D 2012, I have a main alignment with an offset. When I create my datum surface to compute earthwork, it is only creating the surface for the main alignment and not incorporating the offset at all. How can this be corrected?
Fixed. Instead of using feature lines for the surface, I used links and that incorporated the offset alignment.
