Civil 3D Forum
Object listing
6 REPLIES 6
222 Views, 6 Replies
Object listing
Is there a way to count all types of object in a drawing?
Like this:
Command: ????
Number of blocks: 22
Number of 3d faces: 2
Number of hatches:1
"Qselect" does it but it can be very slow if there are a large number of objects in the file.
I guess this information is savea as "meta data" and can be accessed even without opening the file???
6 REPLIES 6
One more thing:
Select or Qselect does not work if the number is greater than 32000?
troma
Ctrl + A
Then go to your properties (Ctrl + 1)
Drop down the list at the top, it numbers each object.
Not great for a huge drawing  maybe, but it's something like what you wanted.
Mark Green
Working on Civil 3D in Canada
in reply to: troma
As I mentioned there is a limit of 32000 objects using Properties!
But Thanks anyway!
troma
If I were you I would have a look over at the lisp forum or just on the web with your favourite search engine.  I'd be surprised if it hasn't been done before.
Mark Green
TerryDotson
If you were to consider third party software, ToolPac contains this functionality (and much more).
SurveyorLee
Have you tried SSX or a similar lisp or VBA.  They will tell you how many instances of a block are found, including how may are not in the currrent space.
Surveyor Lee
Rail Community
