AutoCAD Civil 3D General
Member
kaanturkum
Message 1 of 4 (591 Views)
Object Viewer Pivot Point...?
591 Views, 3 Replies
10-05-2012 01:16 AM
  Hi Everyoe,
I have some objects (corridor / intersection corridor / surface / grading ...)  in civil 3d 2013
When we rotate the 3d objects , object rotate pivot point  about (0,0,0,   or any place x,y,(z=0)
So rotated 3d object (if the Z= High value)  can't be seen / can be seen as a point.
how to change the object viewer pivot point ?
(not using steering wheel or zoom extents  because of first time rotating objects seen so far )
Product Support
AlmasSuljevic
Message 2 of 4 (561 Views)
Re: Object Viewer Pivot Point...?
10-08-2012 06:22 AM in reply to: kaanturkum
Hi kaanturkum,
I personally am not sure about the question. Can you elaborate a bit more and perhaps post your image or drawing for others to see?
The only thing that comes to mind is Set View settings or Constrained 3D Orbit in Object Viewer (icons) that may be causing something similar.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
*Expert Elite*
jmayo
Message 3 of 4 (553 Views)
10-08-2012 06:49 AM in reply to: kaanturkum
Enter the 3dorbit command. Right click and confirm  your settings with the attached. I think Autotarget and contrained orbit are what you need.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Valued Contributor
Message 4 of 4 (319 Views)
05-14-2013 02:11 PM in reply to: jmayo
Yes. 3dorbit works for this, but why doesn't it work in the event viewer. The advantage to the EV is that you aren't actually manipulating your view, just inspecting it, once you leave the viewer, your view is unchanged. Not the case for 3dorbit, which actually changes your current view. Requiring an undo, which seems to have taken a hit in terms of stability over the last few releases. Some lazy programming going on, in any case, the event viewer pivot, used to work.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
