Civil 3D Forum
OVERLAYWIDENWITHSUPER1 zero cross slope glitch
6 REPLIES 6
502 Views, 6 Replies
with the default cross slope 2% in place and no profile targets, section views with subject sub assembly come up at 0%
there's some polyline width targets but no verticals...
any thoughts?
thx!
6 REPLIES 6
sboon
Check the superelevation parameters for the alignment.
Steve
Expert Elite Alumnus
in reply to: sboon
the alignment has no super parameters, therefore it seems the defaults in the subassemblies should dictate
other thoughts?
thx,
sboon
I just checked the help and the parameters for the sub.  I don't see a default slope parameter, and the help indicates that the lane slope always comes from the superelevation.  Perhaps we're talking about different subassemblies or different versions?
Steve
in reply to: sboon
I'm using 2012
In help under "layout mode operation" it sure seems to imply -2%, also in your graphic it shows a -2% slope value...
But I'm guessing you're on the right track.  However I've got a long tangent road and the super wizard simply returns "no curves on alignment" and the tabular editor won't let me add anything.  So I can't simply add 2% normal crown for the length of the roadway, hoping the assembly would kick in.
Any last thoughts?
again much obliged,
sboon
The superelevation parameters won't calculate and the software won't allow you to add anything until you have a design speed set for the alignment.  Open the Alignment Properties dialog, switch to the Design Criteria tab and use the button to add one.
I tried some experimenting with a single tangent alignment like yours and ran into the same problem - without any curves you cannot enter any superelevation values.  I ended up adding a very small three point curve to the end of the alignment then used masking to hide it.  Once that was done I could add the superelevation.
Steve
in reply to: sboon
you da man!
Thank you!
Rail Community
