I know this is an install question but I want to see if other c3d have experienced it?
I created, deployed and installed (only on my machine so far) civil3d 2014. The Raster cui is part of the ribbon but none of the commands were recognized. I checked the search paths and there were no sp to raster as part of the ootb install. I added the paths manually and everything worked fine.
my question is : has anyone else experienced this with thier civil3d install of 2014
Your Name
Your Name
Solved by rkmcswain. Go to Solution.
Hi Joe,
Never clicked on any of the commands on the Raster Tools Tab of Ribbon but yes I can confirm that mine may not be working either.
Having said that I'm just clicking away at commands in a C3D survey topo dwg with no images involved.
Are these the type of errors you're seeing?
c:\program files\autodesk\autocad raster design 2014\aeciremui57.arx cannot find a dll or other file that it needs.
Unknown command "ISPOLYREG". Press F1 for help.
Unknown command "ISSMART". Press F1 for help.
c:\program files\autodesk\autocad raster design 2014\aeciibui57.arx cannot find a dll or other file that it needs.
Unknown command "IDESKEW". Press F1 for help.
c:\program files\autodesk\autocad raster design 2014\aecivtui57.arx cannot find a dll or other file that it needs.
Unknown command "VTEXT". Press F1 for help.
Thats correct: add these two lines to options searcg path and they should work
Your Name
Your Name
Yes I have seen that oddity. You have the correct fix but I do not believe the Help folder is required anymore. I think 13 & 14 run w/o it.
John Mayo
Your Name
Your Name
Nice is right, we only have around ~100 machines that exhibit this oddity! Now I know what to do in my spare time.
Your Name
Your Name
Civil 2014 or Infrastructure Design Suite 2014?
I know ARD comes with IDSP, but does it come with basic C3D that is not part of a suite?
FWIW - we have IDSP 2014 and ARD works fine.
ISDSP
ARD works fine now that I added the path manually
Your Name
Your Name
Those paths appear in my Support File Search Path. But I don't think I entered them manually. I installed IDSP 2014 from a network deployment.
I'll have to create a new deployment and reinstall on a new computer in the next few days. I'll keep an out for the oddity then.
Allen
Allen Jessup
CAD Manager - Designer
Oh S#%T!
I just remembered when I installed IDSP C3D did not work (I seem to have trouble every time, with the flash drive media they send), so I downloaded C3d solo - thats why there is no path.
what a dummy.
Your Name
Your Name
Your Name
Your Name
