Hi troyhill,
What plotter do you use and what Plot Style type (CTB or STB)? Can you plot preview and then plot it using DWG to PDF.pc3. Do you still get the same results?
Also, if you select your OLE object in your drawing, right-click and go Properties. Then see if you can change your Plot Quality to Monochrome. Will that work?
