Nothing appears as the “Stakeout Alignment Report” is executed,
I wanted to execute the “Stakeout Alignment Report” (attached) but nothing appears! This is despite the fact that:
What might be the issue then?
Thank you
Best
Jamal
This report requires there to be at least 2 Points in drawing in order to run
One point to be specified as "Point Occupied" and one point as "Backsight Point".
Many thanks Jay,
Which points in the attached curve are to be considered for the point occupied and the backsight point in order to have angle-distance scenario (second screenshot) implemented to stake out the curve on the field?
You, the operator, should know what points you have in the field. YOU determine where you want to set up the instrument and what point to use for the backsight.
Bill
Many thanks Bill. It works fine (attached)
The issue now is:
Best
Jamal
