Civil 3D Forum
Nothing appears as the “Stakeout Alignment Report” is executed,
4 REPLIES 4
JamaL9722060
1127 Views, 4 Replies
I wanted to execute the “Stakeout Alignment Report” (attached) but nothing appears! This is despite the fact that:
  1. The IE is set as default browser (attached)
  1. The Active X is enabled (attached)
What might be the issue then?
Thank you
Best
Jamal
Jamal Numan
4 REPLIES 4
Jay_B
in reply to: JamaL9722060
This report requires there to be at least 2 Points in drawing in order to run
One point to be specified as "Point Occupied" and one point as "Backsight Point".
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
JamaL9722060
in reply to: Jay_B
Many thanks Jay,
Which points in the attached curve are to be considered for the point occupied and the backsight point in order to have angle-distance scenario (second screenshot) implemented to stake out the curve on the field?
Jamal Numan
wfberry
You, the operator, should know what points you have in the field.  YOU determine where you want to set up the instrument and what point to use for the backsight.
Bill
JamaL9722060
in reply to: wfberry
Many thanks Bill. It works fine (attached)
The issue now is:
  1. Having the angle in degree/minute/second
  2. Having the report as table in the C3D
Best
Jamal
Jamal Numan
Rail Community
