Civil 3D Forum
Northing and Easting Labeling
12 REPLIES 12
Message 1 of 13
martin888888
5532 Views, 12 Replies
Does anyone know if there is an Autocad LISP routine you can find somewhere that labels northings and eastings when you pick a point?  This would be for data to add to a plan sheet in paper space.
12 REPLIES 12
Message 2 of 13
mfernandes
in reply to: martin888888
how about creating a general note style with the northing and Easting, if you want to label a location on a map without placing a C3D point.
but if you are looking for coordinates referance in paperspace, take a look at Map books feature.
Message 3 of 13
AllenJessup
If you're interested in a Note Style. This is what ours looks like.
Allen
Allen Jessup
CAD Manager - Designer
Message 4 of 13
martin888888
in reply to: AllenJessup
thanks guys, works like a charm.  I need to take a class on styles.  It doesnt seem to work in paper space, is there a setting for that?
Message 5 of 13
AllenJessup
No. Since it's world coordinate based it can't work in paperspace. I tried the ChangeSpace command but that doesn't work either. I would think that even if it did. You'd just get coordinates based on the paper size.
Allen
Allen Jessup
Message 6 of 13
dg
Why did Autocad go and change this simple function. If it aint broke why fix it. Now you have to take 5 steps to get a foot ahead.
Message 7 of 13
AllenJessup
in reply to: dg
Once you create the Label Style and save it in your Template. You can access it easily.
Allen
Allen Jessup
Message 8 of 13
kcook
What you seem to fail to understand is there simply was no need to change it!  N&E labeling is constantly used and should have remained a simple pull down.  It may be simple to reference once created but we have to sift thru the internet to figure out how to recreate the wheel.
Message 9 of 13
wfberry
in reply to: kcook
Look at the big picture.
The dropdown would only give one format.
This way:
1. Dec. degrees
2. DMS spaced or not spaced
3. One of the above either to  Deg only, to minutes or seconds.
Several other reasons.
Bill
Message 10 of 13
Pointdump
in reply to: kcook
K,
"...we have to sift thru the internet to figure out how to recreate the wheel."
Nope. All you need to "sift through" is the Help Section, which I find to be easy to use. Allen's Note Style can be created in under a minute. Two minutes if you have a delightful cup of coffee next to your computer.  SmileyWink.gif
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 11 of 13
kcook
in reply to: Pointdump
Unfortunately not that easy for me. I would like to know how to include it
in a leader.
Kevin E. Cook, P.E.
Director of Engineering
part1.08070605.03030705@chmpincCHMP, INC.
5198 Territorial Road
Grand Blanc, MI 48439
Telephone: (810) 695-5910
Fax: (810) 695-0680
Message 12 of 13
Pointdump
in reply to: kcook
Kevin,
All label styles have a dragged state which will give you a leader.
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 13
AllenJessup
in reply to: kcook
You or I may have had no need to have it changed. But there were constantly post in LDD and early Civil 3D about how to do labels differently. Autodesk had instituted Styles which are very powerful and allow the user to customize labels in many different ways. But as with most things. The more power you have the longer it takes to learn to utilize it.
Allen
Allen Jessup
Rail Community
