Civil 3D Forum
Northing & Easting entry? Help
2 REPLIES 2
cadman33619
2598 Views, 2 Replies
i need to verify a point on the drawing and all i have are the northing and easting coordinates. however, they look weird to me and i can't get the line command to work using them. they are:
easting 173,606.4123
northing 222,309.0474
i've seen northing/easting points in the for of xxx.xxx, xxx.xxx but not like these.
How can i enter these?
thanks
2 REPLIES 2
Jason.Hickey
in reply to: cadman33619
Northing is Y, Easting is X. You're simply entering a coordinate. You can create a point with the point creation tools, or you can draw a line from X,Y to some arbitrary location. Or, if you want to entre them by northing/easting, you can use the 'NE transparent command. There are many, many ways that you can verify this point.
Jason Hickey
Premium Services Specialist
Autodesk, Inc.
neilyj666
The thousands comma separator is a bit unusual in my experience.....try typing in as 173606.4123 and 222309.0474
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
