Civil 3D Forum
Node osnap not recognizing certain point marker styles
7 REPLIES 7
Message 1 of 8
Jason__M
3129 Views, 7 Replies
Is there a reason why the "node" osnap won't recognoze certain point markers?  I have recently begun using named plot styles and I have been revising some of our markers to reflect this.  I have noticed that some of the point markers (it seems like markers that use a circle as part of the marker) won't show the node marker no matter how I hover around it.  Others seem to be normal.   Thanks for any help.
7 REPLIES 7
Message 2 of 8
AllenJessup
in reply to: Jason__M
Which release of Civil 3D are you using? I've been told that 2013 will node snap to all markers and previous version don't.
Allen
Civil 3D 2012
Allen Jessup
CAD Manager - Designer
Message 3 of 8
rl_jackson
When this happens, insert the block used in the points style, go into block editor by selecting the block and right-clicking. Then go through and recreate things a little, I have had it happen on my point styles as well.
Rick Jackson
Survey CAD Technician VI
Message 4 of 8
Neilw_05
Welcome to the world of custom ARX objects. I wonder how much time has been wasted by users trying to figure out how to snap to geometry of C3D objects.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 5 of 8
AllenJessup
in reply to: Neilw_05
A lot. I still want to know why I can get an endpoint or nearest osnap on a profile but not a perpendicular or intersection.
Allen
Allen Jessup
Message 6 of 8
Jason__M
Forgive my ignorance.  When you say time wasted is it wasted because people don't know the right way to fix it, or is it wasted because people spend time trying to fix something that might no be fixable?
I am currently using 12.  I tried the markers out in 13 and Allen seems to be right.  They worked like a champ there.  I guess it's time to reluctantly move up.
Thank you all.
Message 7 of 8
AllenJessup
That might not be reason enough. At least not till the first SP, There's always the 'PN or 'PO transparent command to "snap" to a point.
Allen
Allen Jessup
Message 8 of 8
Jason__M
in reply to: AllenJessup
I didn't think about 'PO.  That's much better than moving up.  Thanks again!
Rail Community
