Can anyone tell me how to add the delta to a label style at grade breaks in the profile view? Do I need to create an expression to accomplish this?
Do you want the delta as an angle, or would the grade change parameter work for you?
Grade change is one of the parameters that you can add to a profile label.
Watch out for grade changes where your profile goes through the horizontal. You could find that it's switching between positive and negative values.
I did it using ATAN(ABS({Grade Change}))
It seems to almost get it right but when I check it by drawing some angular dimensions on the profile I am noticing small errors. The error seems to get worse as the amount of grade change increases - for example at a delta of 88 degrees the error is 0.3
Change the block name for the marker to AeccTick Triangle for the Grade Break in your Profile style. See attached, Is this what you are looking for?
