I have seen all kinds of posts, but with no real solutions for this...
I am trying to create several new tool palettes in Civil 3D 2015, but they keep disappearing when I restart.
Does anyone know how I should be doing this?
Regards.
Ross.
Solved by RDunkley. Go to Solution.
- The paths in the Options Dialog remain the same before & after...
- The Custom Palette file in Windows Explorer doesn't get written (I think this is the issue...?)
- In the Customize Palettes command I can create new Groups & New Palettes etc. but they will all be missing after a restart...?
Regards.
Ross.
I managed to create a new one by ensuring that my Local Folder (The one with the AcTpCatalog.atc file) was set as the first in my list in the 'Options...' Tab.
After opening up Civil 3D again and then closing, I located the New Palette on my Local drive and copied (I had to leave one copy there to start with...?) to my second location (Which is also on my Local drive). I then set the Local Folder (The one with the AcTpCatalog.atc file) back to the second in the list, closed Civil 3D and was then able to delete the original...
Not sure this will work for everyone, but seemed to for me.
Regards.
Ross.
