Using part builder, I created a new pipe part for an odd-sized CMP arch pipe. In plan view, the pipe looks good. At first glance, I thought the pipe was drawn correctly in a profile view, but I realized that the pipe was displayed with the invert located at the wrong place in the profile view. I thought this was because the insertion point of the new pipe part that I had made was placed at the incorrect location in part builder.
So, I swapped out the incorrect pipe size for another one that I knew was correct, and then deleted the incorrect pipe from the pipe parts list, and went back to part builder, and placed the insertion point at the invert of the pipe; then saved the edited pipe part, ran partcatalogregen, added the "corrected" pipe part to the pipe parts list and swapped in the new corrected pipe size to the pipe network. However, the pipe still displays incorrrectly on the profile view.
The pipe data is correct in the pipe properties: the invert is stated to be located at elevation 20. The overall height of the pipe , 38" (3.1667') is correctly displayed on the profile view. But the actual location of the pipe invert is not shown at the correct location, elevation 20, on the profile view.
Does anyone have any suggestions on how to correct this? Did I do something wrong in part builder?
Thanks for any help you all can provide!
Attached is the .dwg file this occurs in.
I'm not sure where I went wrong. The pipe's properties are set correctly in the pipe properties palette.
Any guesses, hunches, etc. are welcome!
Hi Matt,
Thank you for providing the CAD file. Could you also upload the Pipe part files, so I can take a look at them in part builder?
Also, did you create these pipes from scratch, or did you copy an existing part and modify it?
Jason,
I created the 38x57 CMP arch from scratch.
Attached are the part files in a compressed folder.
Please give this part a try and let me know if this resolves your issue.
