I'm getting anew PC and have made many changes to right click menus etc etc in Civil 3D.
Can these be transferred easily or do I have to manually change them all over?
neilyj (No connection with Autodesk other than using the products in the real world)
If the content is split out into CUIx files other than the core product ones, it will be much easier. If the content is referencing commands from the core product there might need to be some rebuilding to account for obsolete or modified commands. If you use the Transfer option in the CUIx editor, I *think* it creates clones of those commands in the destination CUIx which can lead to command bloating. With everything done in non-OOTB CUIx files I've always manually copied the CUIx files, then directly modified those files with the new version.
