Civil 3D Forum
New Dell Computer Specs
9 REPLIES 9
Message 1 of 10
Weathington
1583 Views, 9 Replies
I am searching for 2 new Dell Desktops for our office.  We use AutoDesk Infrastructure Design 2014.
I need help on which Dell computer/workstation to start configuring and what video card to use (needs to be dual montior capable).
9 REPLIES 9
Message 2 of 10
If you are going to be working in Infraworks, make sure you get a solid state hard drive.  Check video cards on the hardware compatibility website...
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112&-detail
Todd Rogers
Message 3 of 10
neilyj666
in reply to: Weathington
My system works pretty well for my needs and although I haven't got into much Infraworks/3ds Max stuff yet I'm sure it'll be more than capable....
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 4 of 10
Weathington
in reply to: neilyj666
Neilyj,
If you don't mind me asking about how much did that setup cost?
Message 5 of 10
bf
I just went through the same thing not too long ago.  Am running the same 2014.  Haven't had any problems.
Dell
Xeon E5-1620 3.6 Ghz
16 GB RAM
2 GB Quadro 4000
230GB SSD drive
300 GB SATA Second drive
No trial versions of programs
I also talked to Xi computers and could get what I wanted for less ( I wanted a different and faster processor) but our outsourced tech guy wanted Dell and my boss went with that.
Message 6 of 10
joantopo
you can use nvdia quadro with nview aplication but nvdia doesn't give support driver for c3d 2013, 2014...
i'm dissapointed about this.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Message 7 of 10
neilyj666
I'm afraid I don't know - the IT guy sourced it after I pointed him in the right spec direction...:)
Message 8 of 10
bf
and if you look at Autodesks approved specs, they only tested the ones they list.  They didn't test a whole lot.
Message 9 of 10
Weathington
in reply to: bf
Is it worth getting the Xeon over the i7?
Message 10 of 10
dgorsman
Usually not, unless you are getting a bulk corporate deal from HP, Dell, or another big distributor.  For single computers or a handful, i7 (or even an i5) all the way.
Rail Community
