Civil 3D Forum
.Net modules not found
3 REPLIES 3
jmayo-EE
854 Views, 3 Replies
None of my subassemblies are showing in 2011. I have not modified the default path to the toolpalletes.  The event viewer shows this message.
[Subassembly.LaneOutsideSuper].Net subassembly project, module, or class not found  (Source: )
I did just install SP1 but I do not know if I had this issue prior to the update.
Anyone know how to get the subassemblies and/or .Net back without a reinstall? I do have a network location for the C3D data folder. Is this the issue?
John Mayo
3 REPLIES 3
AlmasSuljevic
in reply to: jmayo-EE
Hi John,
.NET Framework could be found in your ...AdminImage\x64\support\dotnetfx\wcu\dotNetFramework directory. As far as missing sub-assemblies I think you would need to start with repair of install after you reinstall .NET.
If installation is successful palettes catalogs should be copied into:
C:\ProgramData\Autodesk\C3D 2011\enu\Tool Catalogs\Road Catalog
If you are missing these (54 on my machine) objects then you may be having a bad install.
Hope this helps.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
jmayo-EE
in reply to: AlmasSuljevic
Thanks!
I'll look into this in a bit.
John Mayo
We're having the same problem.  We also have our data folder in a network folder.  Anyone find a solution?
Rail Community
