Hi, I am new to Civil 3D. I have this contour lines from dwg file (see attached) and I am trying to make a surface out of it. Initially i thought it is already a surface for C3D but i cant seem to follow tutorials. While browsing for solutions from the Internet, it seems it is not even a contour file that can be added in C3D.
Can someone provide some guidance as to what is this file and how i can convert it into a surface in C3D?
It might have started out as a Civil surface but it isn't one anymore.
Select all the objects and explode which will create 2D poly lines at elevation (i.e. contours) which can then be added to a surface definition; review the "create surface from contours" topic in Help
neilyj (No connection with Autodesk other than using the products in the real world)
...and for future reference, contours are probably the least preferred objects for building a surface (unless they have a very small vertical interval e.g 0.05m).
The 3D faces or an XML file are the best for transferring surfaces between different modelling systems
