Ok , so I have a number a questions ... been trying to figure this out for 2 hours now and I thought I should just ask.
How can I create a subasambley
AND hot to add a Pave 3 opption or another subbase depth.
Ichim Andrei
You can create a subassembly using the Subassembly Composer software. Depending on which version of Civil3d you have it may be already installed or you might have to get it from the Subsription download site.
If your corridor has more than one region then you can apply different assemblies to each one.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Joe Bouza
@Joe-Bouza wrote:
Set them to 0.0000001
Are you being cryptic, or am I just slow today?
You should be able to set any depth to 0 and the layer won't draw. I tried a few of the Lane subassemblies in 2014.
Peter Funk
Autodesk, Inc.
Now that I have heard it from the source I will not fear doing that.
My civil3d is kind of like my guitar playing: I can make them both work pretty well but to the trained eye they may not look so pretty
Thank you Peter
Joe Bouza
"Now that I have heard it from the source I will not fear doing that."
I have been approximating zero for some time now as well. 🙂
John Mayo
Thank you I was feeling all alone for a...second
Ever fearfull of the dreaded "Division by Zero"
Joe Bouza
"You should be able to set any depth to 0 and the layer won't draw. I tried a few of the Lane subassemblies in 2014."
This makes sense it should operate and behave like this.
However, are you checking the programming code also? What does "layer" mean here?
I would like to be sure that no Links or Shape remnants are being created for double counting areas in QTO, Rendering, etc..
Joe Bouza
Hi Peter
here is a sample of why I use 0.00001
Joe Bouza
Is this only for C3d 2014?
This is not true Peter. See message from support below.
I am being challenged by support to take this to development as a defect.
We need you to have development thoroughly go through all of the subassemblies to check for this functionality. We rarely have all the offered Material layers in our road structural design at once. For example, maybe we just have a Pave1 and Pave2 layer and Base layer. No Subbase, Pave3, etc.
We need to have confidence that these layers are NOT CREATED for quantification in QTO and Volume Reports. Also for Hatching, Rendering, etc.
The subassemblies do not display coorectly in Section view. The unwanted Material layers are created.
