Civil 3D Forum
Need help with assambleys
15 REPLIES 15
Message 1 of 16
ichima
391 Views, 15 Replies
Ok , so I have a number a questions ... been trying to figure this out for 2 hours now and I thought I should just ask.
How can I create a subasambley
AND hot to add a Pave 3 opption or another subbase depth.
Ichim Andrei
15 REPLIES 15
Message 2 of 16
ichima
in reply to: ichima
One more question , can you combine 2 asambleys into one corridor ?
Message 3 of 16
sboon
in reply to: ichima
You can create a subassembly using the Subassembly Composer software.  Depending on which version of Civil3d you have it may be already installed or you might have to get it from the Subsription download site.
If your corridor has more than one region then you can apply different assemblies to each one.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 4 of 16
ichima
in reply to: sboon
|f your corridor has more than one region then you can apply different assemblies to each one."
How ? Can you explain some steps ? Sorry ! I am just learning this CIvil 3D
Message 5 of 16
Joe-Bouza
in reply to: ichima
Set them to 0.0000001
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 6 of 16
sboon
in reply to: Joe-Bouza
Are you being cryptic, or am I just slow today?
Steve
Message 7 of 16
You should be able to set any depth to 0 and the layer won't draw. I tried a few of the Lane subassemblies in 2014.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Message 8 of 16
Now that I have heard it from the source I will not fear doing that.
My civil3d is kind of like my guitar playing: I can make them both work pretty well but to the trained eye they may not look so pretty Smiley Very Happy
Thank you Peter
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 9 of 16
jmayo-EE
"Now that I have heard it from the source I will not fear doing that."
I have been approximating zero for some time now as well. 🙂
John Mayo
Message 10 of 16
Joe-Bouza
in reply to: jmayo-EE
Thank you I was feeling all alone for a...second Smiley Wink
Ever fearfull of the dreaded "Division by Zero"Smiley Surprised
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 11 of 16
fcernst
in reply to: peterfunkautodesk
"You should be able to set any depth to 0 and the layer won't draw. I tried a few of the Lane subassemblies in 2014."
This makes sense it should operate and behave like this.
However, are you checking the programming code also? What does "layer" mean here?
I would like to be sure that no Links or Shape remnants are being created for double counting areas in QTO, Rendering, etc..
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 12 of 16
jmayo-EE
No your not alone. There were issues with some of the subs in earlier releases.
John Mayo
Message 13 of 16
Joe-Bouza
Schweeew! <G>
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 14 of 16
Hi Peter
here is a sample of why I use 0.00001
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/This-is-why-I-use-0-00001-for-zero-thickness-on-sub-a...
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 15 of 16
blt
Is this only for C3d 2014?
Bryan Thorp, PLS
Civil 3D 2017 SP1
Dell OptiPlex 990 Workstation
Intel I7
16 Gig of RAM
Message 16 of 16
fcernst
in reply to: ichima
This is not true Peter. See message from support below.
I am being challenged by support to take this to development as a defect.
We need you to have development thoroughly go through all of the subassemblies to check for this functionality. We rarely have all the offered Material layers in our road structural design at once. For example, maybe we just have a Pave1 and Pave2 layer and Base layer. No Subbase, Pave3, etc.
We need to have confidence that these layers are NOT CREATED for quantification in QTO and Volume Reports. Also for Hatching,  Rendering, etc.
The subassemblies do not display coorectly in Section view. The unwanted Material layers are created.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Rail Community
